[gdal-dev] ERDAS ECW JPEG2000 SDK v4.1
Even Rouault even.rouault at mines-paris.org
Sun Aug 29 14:39:39 EDT 2010
> It certainly should be easier to use, since it is a binary library, like
> Lizardtech does for mrsid, so you don't have to worry about compiling the
> library.  The what's new pdf says it supports the old 3.x interface, so it
> should not be too much trouble to integrate into the current GDAL.
Or not... The doc says the C interface is compatible, but GDAL uses the C++
one. Looks like Frank has anticipated some work to be done before bringing
support for the new SDK : see http://trac.osgeo.org/gdal/ticket/3676
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to
> possess - money to purchase the effeminate pleasures of weaklings.  And
> yet withal bound down by silly customs that make them slaves to their
> unhappy lot while firm in the belief that they be the lords of creation
> enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
