[gdal-dev] ERDAS ECW JPEG2000 SDK v4.1
Matt Wilkie matt.wilkie at gov.yk.ca
Mon Aug 30 13:05:18 EDT 2010
> Chaitanya started looking into it, but after contacting Erdas it turned out
> somewhere there was already working on GDAL updates for the new SDK.  I am
> not sure where that stands now, but I do have a client interested in
> having it incorporated so it *should* happen fairly soon.
the website /now says/
<http://www.erdas.com/tabid/84/currentid/1142/default.aspx>:/
//*Timesaving GDAL Integration*
Save time by accessing the ERDAS ECW JPEG2000 SDK via the Geospatial
Data Abstraction Library (GDAL) interface. By simply adding the SDK,
developers already using GDAL can easily provide ECW and JPEG2000 read
support in desktop applications (without having to learn an additional
toolkit).
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 29/08/2010 11:47 AM, Frank Warmerdam wrote:
> Even Rouault wrote:
>>> It certainly should be easier to use, since it is a binary library, like
>>> Lizardtech does for mrsid, so you don't have to worry about compiling the
>>> library.  The what's new pdf says it supports the old 3.x interface, so it
>>> should not be too much trouble to integrate into the current GDAL.
>> Or not... The doc says the C interface is compatible, but GDAL uses the C++
>> one. Looks like Frank has anticipated some work to be done before bringing
>> support for the new SDK : see http://trac.osgeo.org/gdal/ticket/3676
> Folks,
> Best regards,
