[gdal-dev] Re: Require Help Transforming into Equirectangular
ssobieraj ssobieraj at cdlsystems.com
Wed Dec 1 11:51:52 EST 2010
Hi Jean-Claude,
Thanks for the help.
To test the effect that I was getting, I created a total of four images.
Two in Sinusoidal projection, using WGS84 and RT90, and another pair using
Lambert Equal Area (again with both WGS84 and RT90 datum).  I then compared
these to an unaltered Equirectangular projected image in WGS84.
The results seemed odd and so I've provided them below:
The Sinusoidal projections were both 16km from my source, regardless of
whether I used RT90 or WGS84.
The Lambert projection using WGS84 transformed back perfectly.
The Lambert projection using RT90 transformed back with a ~900m error,
similar to what was seen when I used Vincent's method above.
So it's possible that the +towgs84 parameters are at fault, but then why
would the Sinusoidal/WGS84 be as bad as the Sinusoidal/RT90?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Require-Help-Transforming-into-Equirectangular-tp5789691p5792571.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
