[gdal-dev] Using GDAL16.DLL within a C++ application
Helm, P.W. (Pim) van den pim.vandenhelm at tno.nl
Thu Dec 2 07:54:19 EST 2010
Hi All,
I want to use GDAL within my project. I only need the geospatial transformation to change coordinates between geospatial systems. So using the FWTools will put me up with an enormous amount of extra DLL's needed within the project that will never be refered.
So looking at GDAL was my solution with lot less of additional DLL's. Unfortunately my build on 1.7.2  fails on the wce_time.h link for some reason. But I don't mind using the win32 build of GDAL1.6, but how???
I am used to get my DLL's linked via the .lib file and a reference to the header. Now I probably need to create a wrapper to match my used functions, but what are they? Or are where can I get the needed header files and .lib file?
If not is there another method to get an easy usage of this library?
Kind regards,
Pim
This e-mail and its contents are subject to the DISCLAIMER at http://www.tno.nl/disclaimer/email.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101202/43008350/attachment.html
