[gdal-dev] Projection aeqd and geotransform
Paco Regodón mapserver at meteologica.es
Thu Dec 2 10:31:17 EST 2010
Hello all,
i'm trying to create an VRT file for a raster in azimutal equidistant
projection. I am almost sure the projection i should use is
+proj=aeqd +lat_0=YYYYY +lon_0=XXXXX +x_0=0 +y_0=0 +units=m
XXXXX and YYYYY being the raster's center coordinates.
I know the pixel width is 1000 meters, but i don't know how to write a
geotransformation since i don't know the upper left pixel coordinates.
Anyone can help me? Can i define a geotransform with a central pixel
instead of the upper left one?
<VRTDataset rasterXSize="480" rasterYSize="480">
<SRS>+proj=aeqd +lat_0=39.177500 +lon_0=0.249722 +x_0=0 +y_0=0
+a=6371000 +b=6371000 +units=m</SRS>
<GeoTransform>??????, 1000, 0, ??????, 0, -1000</GeoTransform>
<VRTRasterBand dataType="Byte" band="1" subClass="VRTRawRasterBand">
<SourceFilename relativeToVRT="1">cullera.raw</SourceFilename>
</VRTRasterBand>
</VRTDataset>
Thanks,
Paco Regodón
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101202/4377399d/attachment.html
