[gdal-dev] Running gdalwarp over ECMWF's NetCDF
antonio.rocha at deimos.com.pt antonio.rocha at deimos.com.pt
Thu Dec 2 15:30:08 EST 2010
Greetings
I have just analyzed the output grom gdal1.7.1 and It's wrong...
Gdalwarp just copied the NetCDF coordinates (corner coordinates) it
did't warp the coordinates.
Maybe I have to define Input system (s_srs). ECMWF provided me the
orifginal system that is:
Latitude/longitude or equidistant cylindrical or plate carree grids.
Can anyone indicate me the EPSG?
Can this be the solution?
I have attached to this email the output of this command (gdalwarp
-t_srs EPSG:3763 2009.nc 2009.tif) in Windows with GDAL1.7 (thanks for
the tip Even).
As you can see, it just copied the coordinates to the target CRS. Does
anyone have any suggestion on how to fix this/how to do this in the
right way?)
Thanks
Antonio
Quoting "Even Rouault" <even.rouault at mines-paris.org>:
> Le jeudi 02 décembre 2010 18:22:54, António Rocha a écrit :
>> Greetings
>> I have runned the same gdalwarp command and I got two different results
>> Command:
>> gdalwarp -t_srs EPSG:3763 2009.nc 2009.tif
>> In Ubuntu (with GDAL 1.7.1, released 2010/02/08) It procuded the raster
>> file In Windows (with OSGEO4w and GDAL1.5.4) I got the eerror:
>> Creating output file that is  3Px4L.
>> Processing input file 2009.nc
>> A target coordinate system was specified, but there is no source
>> coordinate system. Consider using -s_srs option to provide a source
>> coordinate system.
>> Operation terminated
>> Is this a limitation of GDAL1.5.4?
> GDAL 1.5.4 being older than GDAL 1.7.1, it is not surprising that the later
> has received some bug fixes than the first one has not. But the good news is
> that you can use gdal16, gdal17 and even gdal18dev in OSGEO4W !
>> Thanks
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 5667 (20101202) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Type: image/tiff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101202/881bae41/2009NCwindows-0001.tif
