[gdal-dev] Error: EPSG code not recognized
Jean-Claude Repetto jrepetto at free.fr
Mon Dec 6 06:40:28 EST 2010
Le 06/12/2010 11:21, António Rocha a écrit :
> Greetings
> I'm using gdal15 and gdal16 and I'm trying to use gdalwarp with the
> following command:
> gdalwarp -s_srs EPSG:9823 -t_srs EPSG:3763 file.nc file.tif and I get
> the error:
> ERROR 6: EPSG PCS/GCS code 9823 not found in EPSG support files. Is this
> a valid EPSG coordinate system?
> ERROR 1: Translating source or target SRS failed:
> EPSG:9823
> The thing is that this EPSG code exists and is this one:
> http://www.remotesensing.org/geotiff/proj_list/equirectangular.html
> Is this a bug? or is there other alternative?
> Thanks
> Antonio R.
Hi Antonio,
EPSG:9823 is not a coordinate reference system, it is only a projection
code.
Jean-Claude
