[gdal-dev] ERROR 1: LZWDecode:Wrong length of decoded string: data probably corrupted
Even Rouault even.rouault at mines-paris.org
Mon Dec 6 13:41:17 EST 2010
> Does it help at all what I did when trying to reduce the memory demand:
> to loop through the geometries by some CODE value? Does gdal_rasterize
> always load *all* the geometries into memory, independent of the -where
> filter ?
It will only load the geometries that match the -where filter, so that helps
reducing the memory demand
> Hermann
