[gdal-dev] Multipart to singlepart
Mon Dec 6 14:03:35 EST 2010
On 10-12-06 06:54 AM, iomeneandrei wrote:
> Hi all,
> is there in OGR a command that I can use to convert multipart polygons in
> singleparts?
Andrea,
At the API or scripting level there is the OGRGeometryFactory::forceToPolygon()
method to try and convert a multipolygon to a simple polygon.  I am not
aware of a way to do this from the commandline utilities.
/*                           forceToPolygon()                           */
  * \brief Convert to polygon.
  * Tries to force the provided geometry to be a polygon.  Currently
  * this just effects a change on multipolygons.  The passed in geometry is
  * consumed and a new one returned (or potentially the same one).
  * @param poGeom the input geometry - ownership is passed to the method.
  * @return new geometry.
OGRGeometry *OGRGeometryFactory::forceToPolygon( OGRGeometry *poGeom )
Best regards,
