[gdal-dev] Error reading long numbers as integer
Ralf Suhr Ralf.Suhr at itc-halle.de
Tue Dec 7 10:10:40 EST 2010
Even,
thanks for the quick help. I have tested SVN21206 and the results fit my
needs.
Am Montag 06 Dezember 2010, 20:56:14 schrieb Even Rouault:
> Ralf,
> > I have created a ticket for the NAS reader. Long numbers (13 digits) are
> > read as integer. Maybe there are more drivers who have the same trouble.
> Yes, this is an issue that can be potentially found in other drivers. The
> situation could improve if/when RFC 31 / OGR 64bit integer is adopted.
> For the time being, I've made a change in the GML driver so that it
> fallbacks to Real when it detects an integer that cannot fit into 32bit.
> Not ideal, but better than arbitrary truncation.
> > I have tested some workarounds. Changing the attribut definition in gfs
> > file is successful, when destination driver is PGdump or Postgresql
> > (create mode).
> Which change did you make exactly ? Change from Integer to Real ?
> > With Postgresql driver as destination ogr2ogr convert the
> > 13 digits number always to integer in append mode and ignoring table
> > definition.
> I'm a bit skeptical about that one. Which exact commands did you use ?
> > I tested with gdal SVN21189.
> > Gr
> > Ralf
