[gdal-dev] Re: Multipart to singlepart
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Thu Dec 9 08:31:49 EST 2010
iomeneandrei <aborruso <at> tin.it> writes:
> Hi all,
> is there in OGR a command that I can use to convert multipart polygons in
> singleparts?
If it does not matter to use some other tool than OGR, OpenJUMP can explode
multifeatures and geometry collections. I made a little test and it correctly
exploded a multipolygon with two polygons containing holes into two simple
polygons with holes. Functionality is behind the right-click context menu.
-Jukka Rahkonen-
