[gdal-dev] basic gdal_translate question
Gregor at HostGIS gregor at hostgis.com
Thu Dec 9 12:45:50 EST 2010
> I would like it to output in degrees. If there an option I can specify
> on gdal_translate to put it in degrees?
> Or is there another utility such as gdalwarp which will do the conversion.
You said it: gdalwarp is how you would reproject a image to a different
SRS, say from UTM to lon-lat.
HostGIS, Open Source solutions for the global GIS community
Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
    Network+   Server+   A+   Security+   Linux+
    PHP   PostgreSQL   MySQL   DHTML/JavaScript/AJAX
"No one cares if you can back up — only if you can recover."
