[gdal-dev] Re: [El] Re: imageio-ext and gdal
Viji V Nair viji at fedoraproject.org
Wed Dec 15 07:30:18 EST 2010
Hi Ralf
What is the conclusion:
1. Are we going ahead with image-io 1.1 and GDAL 1.7.3 OR image-io
1.0.8 and GDAL 1.7.3
2. What about ELGIS 5?
Thanks
Viji
On Tue, Dec 14, 2010 at 4:25 PM, Mathieu Baudier <mbaudier at argeo.org> wrote:
>> # these tests still fail in EL5 environments
>> rm
>> plugin/gdal/gdalgeotiff/src/test/java/it/geosolutions/imageio/plugins/geotiff/GeoTiffTest.java
> eh, eh, even easier!
>> (Tested, i.e. built in mock)
> Please tell me when you are ready to provide an elgis-plus mock config
> file with the JPP 6 repo + an imageio-ext spec file.
> I'm eager to start testing and would also like to start syncing this
> repo on the build servers.
> el mailing list
> el at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/el
