[gdal-dev] libecwj2 ?
Oyvind Idland oyvind.idland at gmail.com
Wed Dec 15 07:59:55 EST 2010
Thanks Ivan,
I forgot to mention that I use GDAL 1.7.3.
It seems to me that the ECW api has changed quite a bit, as 1.7.3 doesn't
compile against it ?
For instance, I get
ecwcreatecopy.cpp(896) : error C2039: 'SetKeySize' : is not a member of
'NCS::CView'
In addition, the NCSJPC_EXPORT_ALL macro is being used, and this one does no
longer
exist in the new SDK.
-- Oyvind
On Tue, Dec 14, 2010 at 3:53 PM, Ivan Lucena <ivan.lucena at pmldnet.com>wrote:
> Ųyvind,
> There is a new SDK that you can download from Erdas website:
> http://www.erdas.com/products/ERDASECWJPEG2000SDK/Downloads.aspx
> But there are a few changes you would need to do in order to compile the
> GDAL/ECW driver because the path and library names has changed.
> Regards,
> Ivan
> >  -------Original Message-------
> >  From: Oyvind Idland <oyvind.idland at gmail.com>
> >  To: gdal-dev at lists.osgeo.org
> >  Subject: [gdal-dev] libecwj2 ?
> >  Sent: Dec 14 '10 07:09
> >  Hello,
> >  i am compiling GDAL from source, and need the ECW as plugin.
> >  The package is mentioned on the site, libecwj2-3.3-2006-09-06.zip, is
> this
> >  a package
> >  from ERDAS ? I tried to find some info about it on their site, but found
> >  nothing..
> >  I found a couple of other download links, so I can at least get started.
> >  -- Ųyvind
> >  _______________________________________________
> >  gdal-dev mailing list
> >  [LINK: compose.php?to=gdal-dev at lists.osgeo.org]
> >  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101215/ae43af9e/attachment.html
