[gdal-dev] Re: GDAL created HFA images unreadable in ERDAS ViewFinder
jeepingben ben_deering at swissmail.org
Wed Dec 15 16:20:12 EST 2010
The image works in the real imagine viewer, so it could be Erdas' problem.
This is what IMAGINE has to say about the image I created:
			Erdas Imagine File Information
File Name: po_1027098_red_0000000.img
Last Modified: Wed Dec 31 19:00:00 1969
Number of Layers: 1
Layer Information:
	Width  : 3587
	Height : 3716
	Type   : Continuous
	Block Width  : 64
	Block Height : 64
	Pixel Depth  :Unsigned 16-bit
	Compression Type : None
	Projection Information :
		Projection Zone  : 0
		Spheroid Name   : WGS 84
		Georeferenced to : Geographic (Lat/Lon)
Ben
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-created-HFA-images-unreadable-in-ERDAS-ViewFinder-tp5838122p5838444.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
