[gdal-dev] An issue about using GDALWARP to do the NTv2transformation
heng.feng heng.feng at aircominternational.com
Thu Dec 16 04:48:33 EST 2010
Brilliant. Thanks, Uwe. I will try that and let you if it works.
From: Schmitz, Uwe [via OSGeo.org] [mailto:ml-node+5841399-2004682561-308251 at n2.nabble.com]
Sent: 16 December 2010 09:44
To: Heng Feng
Subject: AW: [gdal-dev] An issue about using GDALWARP to do the NTv2transformation
Heng,
as Frank wrote the coordinates you try to transform are
far outside the BETA2007.gsb grid. Is it possible that
your georefrenced raster fiel lacks the Gauss-Krueger meridian
prefix? If so, you can try with a modified "+x_0=500000" parameter
on the command line.
Regards
Uwe
gdal-dev mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5841399&i=0>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
View message @ http://osgeo-org.1803224.n2.nabble.com/An-issue-about-using-GDALWARP-to-do-the-NTv2-transformation-tp5838904p5841399.html
To unsubscribe from An issue about using GDALWARP to do the NTv2 transformation, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5838904&code=aGVuZy5mZW5nQGFpcmNvbWludGVybmF0aW9uYWwuY29tfDU4Mzg5MDR8MTI3MzEwMjEw>.
AIRCOM International
http://www.facebook.com/Aircom | http://www.twitter.com/aircomint | http://blog.aircominternational.com/ | http://www.youtube.com/aircomint
Disclaimer:
This e-mail message is confidential and should not be used by, or disclosed to, anyone except the addressee. If you receive this message in error, please advise us immediately on +44 (0) 1932 442000. Since e-mail transmission is not secure or error free, we do not accept responsibility for changes to any e-mail which occur after it has been sent. Attachments to this e-mail may contain software viruses which could damage your systems. You should therefore virus-check all attachments before opening. AIRCOM may monitor incoming and outgoing emails through its networks and by responding to this email, you consent to such monitoring. The views and opinions expressed in this e-mail are those of the author only and not of AIRCOM. We do not intend to enter into any legal commitments or contracts by e-mail. Registered Office: Cassini Court, Randalls Research Park, Randalls Way, Leatherhead, Surrey, KT22 7TW, UK. AIRCOM International Ltd registered in England No. 3052022. VAT number 811 5323 68.
 Save a tree. Don't print this e-mail unless it's really necessary
View this message in context: http://osgeo-org.1803224.n2.nabble.com/An-issue-about-using-GDALWARP-to-do-the-NTv2-transformation-tp5838904p5841413.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101216/b2d38f7e/attachment.html
