[gdal-dev] Re: Performance improvement for gdal_retile
christian.mueller at nvoe.at christian.mueller at nvoe.at
Thu Dec 16 10:30:43 EST 2010
Hi Franks, thanks for your quick answers.
The patch is here
http://trac.osgeo.org/gdal/ticket/3879
The test case test_gdal_retile.py is running and I checked the man
page with doxygen.
Please can you give me a ping after applying the patch to trunk. Since
I am a geotools/geoserver developer and I know about 2 modules
depending on the directory output structure, I will have to make some
noise on the developer lists after your commitment to trunk.
Thanks again for your support
Christian
This message was sent using IMP, the Internet Messaging Program.
