[gdal-dev] Performance improvment for gdal_retile
christian.mueller at nvoe.at christian.mueller at nvoe.at
Sat Dec 18 08:31:21 EST 2010
Some last comment about the test case, the current source checks
test_gdal_retile_2()
ds.GetRasterBand(4).Checksum() != 35
If I run this on a Linux Intel 32 bit configuration, it has to be
ds.GetRasterBand(4).Checksum() != 283
ds.GetRasterBand(4).Checksum() != 122
Doing the same on a Linux AMD 64 Bit configuration, the values should be
ds.GetRasterBand(4).Checksum() != 126
It seems that the cecksum is dependent on the  platform. Is this
desirable ? Could this cause some headaches later ?
Cheers
Christian
This message was sent using IMP, the Internet Messaging Program.
