[gdal-dev] Re: Performance improvment for gdal_retile
christian.mueller at nvoe.at christian.mueller at nvoe.at
Sat Dec 18 09:00:24 EST 2010
Ah, things get complicated :-(. I am working on openSUSE 11.3, 32 Bit
and Ubuntu 10.10 64 Bit. Additionally, I have SUSE Linux Enterprise on
IBM pSeries and IBM zSeries (Mainframe). Some times I even use gdal on
AIX.
I compile against gdal 1.7, no debug mode.
The important fact is that your builds work.
What about checking the check sum against a list of possible values ?
I have developed some test cases for my own and thought about
integrating them into test_gdal_retile.py.  Unfortunately this is not
be possible if I use checksums because I cannot produce the correct
numbers.
For the moment, we can leave it as it is.
Christian
Quoting Even Rouault <even.rouault at mines-paris.org>:
> Le samedi 18 décembre 2010 14:31:21, christian.mueller at nvoe.at a écrit :
>> Some last comment about the test case, the current source checks
>> test_gdal_retile_2()
>> ds.GetRasterBand(4).Checksum() != 35
>> If I run this on a Linux Intel 32 bit configuration, it has to be
>> ds.GetRasterBand(4).Checksum() != 283
>> ds.GetRasterBand(4).Checksum() != 122
>> Doing the same on a Linux AMD 64 Bit configuration, the values should be
>> ds.GetRasterBand(4).Checksum() != 126
>> It seems that the cecksum is dependent on the  platform. Is this
>> desirable ? Could this cause some headaches later ?
> Yes, this is a bit annoying.
> I guess this is related to some compiler difference that impacts numerical
> precision with the bilinear resampling. What is your OS and compiler versions
> ? Do you compile in debug or optimized mode ? Do you use your script against
> GDAL trunk, or do you use it against GDAL 1.7 ?
> 35 works for me on Ubuntu 10.04 64bits, and it also works on all Windows
> builds of Tamas (http://vbkto.dyndns.org/sdk/) that test 7 combinations of
> 32/64 bit and MSVC 1310, 1400, 1500 and 1600.
>> Cheers
>> Christian
>> This message was sent using IMP, the Internet Messaging Program.
