[gdal-dev] Problem with gdal 1.8 -- segmentation fault on large image with gdaladdo
Even Rouault even.rouault at mines-paris.org
Fri Dec 31 10:57:16 EST 2010
Stephen,
I've just managed to reproduce your issue by creating a fake 60000x60000 3
band tif and running gdaladdo on it. Investigating...
Le vendredi 31 décembre 2010 16:44:04, Stephen Mather a écrit :
> Hi All,
>     Testing out gdal 1.8; really excited by
> http://www.gdal.org/gdallocationinfo.html.  Below is a comparison of doing
> the same process in 1.7.3 and then 1.8dev, released 2010/01/19
> $ gdaladdo --version
> GDAL 1.7.3, released 2010/11/10
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> $ gdal_translate -b 1 LEAP_Tree_Height_low_res_test.vrt
> LEAP_Tree_Height_low_res_test.tif
> Input file size is 60000, 60000
> $ gdaladdo -r average LEAP_Tree_Height_low_res_test.tif 2 4 8 16 32 64 128
> 256 512 1024
> sudo make install 1.8
> then:
> GDAL 1.8dev, released 2010/01/19
> 256 512 1024
> 0...10...20...30...40.Segmentation fault
> I've compiled this with ./configure, make, sudo make install on a Mac
> 10.6.5 2.4GHz Intel Core 2 Duo with 2GB memory.
> Thanks,
> Steve
