[gdal-dev] Projection of GEOTIFF in C# problems
Patrik Svensson patsv at bredband.net
Mon Feb 1 18:10:22 EST 2010
Hi all,
I have problem with geotiff files created with gdal_translate when I try to
read them with the C# bindings.
So I tested it with the GDALInfo commands.
GDALInfo.exe  (The c-api) will output the correct projection information:
C:\tmp\release-1500-x64-gdal-mapserver\bin>gdal\apps\GDALInfo.exe w:\Lmv\F
\7h0a.tif
Driver: GTiff/GeoTIFF
Files: w:\Lmv\Foto\7h\7h0a.tif
Size is 5500, 5500
Coordinate System is `'
GCP Projection =
PROJCS["RT90 2.5 gon V",
    GEOGCS["RT90",
        DATUM["Rikets_koordinatsystem_1990",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000009,
                AUTHORITY["EPSG","7004"]],
            AUTHORITY["EPSG","6124"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4124"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",15.80827777777778],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",1500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","3021"]]
GCP[  0]: Id=1, Info=
          (250,250) -> (1550000,6405000,0)
GCP[  1]: Id=2, Info=
          (5250,250) -> (1555000,6405000,0)
GCP[  2]: Id=3, Info=
          (250,5250) -> (1550000,6400000,0)
GCP[  3]: Id=4, Info=
          (5250,5250) -> (1555000,6400000,0)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 5500.0)
Upper Right ( 5500.0,    0.0)
Lower Right ( 5500.0, 5500.0)
Center      ( 2750.0, 2750.0)
Band 1 Block=5500x1 Type=Byte, ColorInterp=Gray
But the c-sharp version has problems with projection string as it only
reports this, lacking the projection data:
C:\tmp\release-1500-x64-gdal-mapserver\bin>gdal\csharp\GDALInfo.exe
w:\Lmv\Foto\
7h\7h0a.tif
Raster dataset parameters:
  Projection:
  RasterCount: 1
  RasterSize (5500,5500)
Using driver GeoTIFF
    0:  INTERLEAVE=BAND
Corner Coordinates:
  Upper Left (0, 0)
  Lower Left (0, 5500)
  Upper Right (5500, 0)
  Lower Right (5500, 5500)
  Center (2750, 2750)
GCP Projection:
GCP[0]: Id=1, Info=
GCP[1]: Id=2, Info=
GCP[2]: Id=3, Info=
GCP[3]: Id=4, Info=
GCP Equivalent geotransformation parameters:
t[0] = 1549750
t[1] = 1
t[2] = 0
t[3] = 6405250
t[4] = 0
t[5] = -1
Band 1 :
   DataType: Byte
   ColorInterpretation: Gray
   Description:
   Size (5500,5500)
   BlockSize (5500,1)
What can I do to get the correct string to give to SpatialReference?
(Tried both GDAL 1.6 and 1.7)
Regards
Patrik Svensson
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100202/01c01e6d/attachment-0001.html
