[gdal-dev] ogr2ogr .SHP to .KML conversion problem
Mattias Carlsson powerphysics at hotmail.com
Wed Feb 3 03:14:05 EST 2010
Thanks, that says version is 1.5.4. I guess an upgrade might do the trick. However, as I am very green in Linux, I have yet to compile my first source and would appreciate any simpler way, i.e. pre-compiled binaries. Is there any such way, or any good reference for learning necessary basics regarding compilation?  /Mattias
Subject: Re: [gdal-dev] ogr2ogr .SHP to .KML conversion problem
Date: Tue, 2 Feb 2010 18:06:28 -0500
CC: gdal-dev at lists.osgeo.org
To: powerphysics at hotmail.com
Use gdal_translate --version
Since you told me that you are using GDAL version 1.5.0 from December 2007, I suggest that you upgrade to GDAL 1.7.0 from January 2010. Greg
On Feb 2, 2010, at 4:01 PM, Mattias Carlsson wrote:Hi,
I am trying to learn how to use ogr2ogr to convert a shapefile to kml, but fail to do so and cannot understand whether I am at all on the right track or completely lost (very much beginner in GIS). I would like to convert either, or all, of the files on <http://www.nationalgrid.com/uk/LandandDevelopment/DDC/GasElectricNW/undergroundcables/shape/> to .kml and try using
>ogr2ogr -f "KML" LINE.kml LINE.shp
but get a buffer overflow (I can send a backtrace if this would help):
>*** buffer overflow detected ***: ogr2ogr terminated
(btw, I am using Ubuntu 9.10)
Apologies if this is the wrong forum or totally basic, but after many frustrations I am getting desperate and, please, please, guide me in the right direction...
Thanks!
\Mattias
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign up now. _______________________________________________
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
_________________________________________________________________
Hotmail: Trusted email with powerful SPAM protection.
https://signup.live.com/signup.aspx?id=60969
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100203/d323daf2/attachment.html
