[gdal-dev] Get Image Endianness
Wed Feb 3 13:03:10 EST 2010
Alejandro Mostovoi wrote:
> Hi All,
> I need to know the image endianness.
> I search for in api's help and list but can't find anything.
> Any idea?
Alejandro,
As mentioned by others the on-disk endianess varies by format and sometimes
by file in a format.  The endianess of data returned by the GDAL API is always
local machine order. So if you read a big endian file on a little endian
system, the RasterIO() calls will return the data to the application in little
endian byte order.
Best regards,
