[gdal-dev] ODBC as OGR data source?
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Feb 3 22:40:39 EST 2010
Gregor,
Your error message should be resolved by an upgrade.
Use the --formats option with ogrinfo to see the status of the ODBC driver.
GDAL/OGR's ODBC driver is currently readonly. Refer to
http://www.gdal.org/ogr/drv_odbc.html and
http://www.gdal.org/ogr/drv_pgeo.html for more details.
On Thu, Feb 4, 2010 at 5:40 AM, Gregor at HostGIS <gregor at hostgis.com>wrote:
> Hey all. I've been asked to set up support for pseudo-spatial data via
> ODBC. So far, I've not had any luck. We're using this as our starting point:
>   http://mapserver.org/input/vector/VirtualSpatialData.html
> But I get this...
> $ ogrinfo ODBC:gregor/mosheh at testPgSQL table
> *** glibc detected *** free(): invalid next size (fast): 0x0000000000505520
> Aborted
> So my very first questions are a) whether the tricks described in that
> document has ever been considered production-stable, and b) whether
> upgrading from GDAL/OGR 1.5.4 to 1.6.3 is likely to help. Then of course (c)
> would be "So what AM I doing wrong?" :)
> The OS is Linux, and I have installed unixODBC and drivers for PostgreSQL
> (bundled with unixODBC) and MySQL (MySQL Connector). I then rebuilt GDAL/OGR
> 1.5.4 including --withodbc=/usr/local/unixODBC
> My odbc.ini is as follows:
> [testPgSQL]
> Description         = Test to Postgres
> Driver              = PostgreSQL
> Database            = MY_DATABASE
> Servername          = MY_HOSTNAME
> Port                = 5432
> Protocol            = 8.2
> ReadOnly            = No
> RowVersioning       = No
> ShowSystemTables    = No
> ShowOidColumn       = No
> FakeOidIndex        = No
> ConnSettings        =
> HostGIS, Open Source solutions for the global GIS community
> Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
>   Network+   Server+   A+   Security+   Linux+
>   PHP   PostgreSQL   MySQL   DHTML/JavaScript/AJAX
> "No one cares if you can back up — only if you can recover."
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100204/843f940c/attachment.html
