[gdal-dev] Re: advice on using the moving average command
Jose Gomez-Dans jgomezdans at gmail.com
Thu Feb 4 07:41:30 EST 2010
On 4 February 2010 08:16, Andrew Wood <andywood.home at gmail.com> wrote:
> For a third time, I am requesting assistance on the issue below.  Does
> anyone in this community know how to use the moving average command to
> produce a grid from a CSV?
Have you read the section entitled "READING COMMA SEPARATED VALUES" on
gdal_grdi's manpage? I did something failry similar to what you want based
on it, and it works fine.
Jose
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100204/e509a0f1/attachment.html
