[gdal-dev] Important - GDAL 1.7.0 - Imagine/HFA Driver Produces Corrupt Files
Norman Vine nhv at cape.com
Fri Feb 5 10:05:36 EST 2010
On Feb 5, 2010, at 9:41 AM, Howard Butler wrote:
> On Feb 4, 2010, at 10:49 PM, Frank Warmerdam wrote:
>> Folks,
>> Ivan has discovered that GDAL 1.7.0 is producing HFA files that are
>> corrupt - that is they are only readable with GDAL.  Imagine and
>> older
>> versions of ArcGIS fail to read them.
>> I consider this problem very serious, and the longer that GDAL 1.7.0
>> is in use the more of these corrupt Imagine files will be produced
>> and
>> cause problems for the world.
> +1.  Except for BigTIFF, the HFA driver is one of the consistent
> large file drivers we have.  Instead of marking it deprecated, I
> think we should retract the release (remove it from
> download.osgeo.org) and immediately issue 1.7.1 RC1 today.
+1 on retracting the release
There are enough poorly formatted images in the wild already
Cheers
Norman
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100205/66870b23/attachment.html
