[gdal-dev] gdal_rasterize use SHP FID as burn attribute
Mon Feb 8 19:56:45 EST 2010
Peter Rankor wrote:
> List,
> I need to rasterize a polygon layer coming from a SHP file. However, the
> values in the outputraster need to be the FID of the corresponding polygon.
> My command:
> gdal_rasterize -a FID -l FECS FECS.shp flattenedRaster.tif
Peter,
Could you try:
gdal_rasterize -a FID \
     -sql "select FID, * from FECS" FEC.shp flattenedRaster.tif
The ExecuteSQL() method invoked for -sql should be able to treat FID
as a pseudo-attribute.  It's a bit unfortunate this sort of thing doesn't
work directly without the SQL route.
Best regards,
