[gdal-dev] how to escape special charakter
Tue Feb 9 10:39:49 EST 2010
Suhr, Ralf wrote:
> Hello list,
> how can I write the commandline to work on a dos box. The dos box says:
> program „name“ is not found. On linux it run fine.
> ogr2ogr -f "DGN" -sql "SELECT 'LABEL(f:\"Times New Roman\",s:12pt,t:\"'
> || name || '\")' AS OGR_STYLE,  *  FROM mytable" export.dgn
> „PG:dbname=..--..“
Ralf,
The problem, I believe, is that the DOS command parser does not understand
backslash escaping to protect the internal double quotes.  I don't really
know if the above can be processed properly by the DOS command parser.
One option might be to install Cygwin which provides a unix-like shell
interpreter (bash) that should follow normal unix rules.
Alternatively, you could possibly invoke os.execl() in python to invoke
a subproject with preparsed arguments.
I had wanted to suggest using the GDAL/OGR --optfile switch which allows
reading command options from a text file, but on review I think the
escaped quotes will also end up confusing it and you will be no better off.
Best regards,
