[gdal-dev] Doubt about memory raster
Tue Feb 9 12:19:49 EST 2010
Jorge Arévalo wrote:
> Mmm... But I suppose this is in case of rasters with pixel type =
> Byte. In that cases, should I always follow this scheme? pArray for
> first band, pArray + 1 for second band, and so on (interlaced)? I
> mean, why don't pArray for first band, pArray + raster_width for
> second band...(non interlaced)?
> Anyway, I'm working in a "WKT Raster format to GDAL format" parser. I
> get all the bands in different arrays: void * pBandData, for example.
> And the pixel type of these bands can be Byte, Int16, Float32, etc.
> So, I don't have one array for all the raster data, I have a different
> one per band.
> In such situation, has sense this scheme?
> DATAPOINTER = pBandData
> PIXELOFFSET = (GDALDataTypeSize(raster_pixel_size) / 8) (this is, 1 =
> pixel size byte, 2 = pixel size int16, 4 = pixel size int32, etc)
> LINEOFFSET = PIXELOFFSET * raster_width_in_px
Jorge,
Yes, this is correct, but you can just omit the PIXELOFFSET and
LINEOFFSET values in this situation since this is the default
configuration.  You only need to specify them if you are doing
something complicated, like interleaving.
Best regards,
