[gdal-dev] BigTIFF Overviews ( OVR files )
David Fogel upperoso at gmail.com
Tue Feb 9 17:35:54 EST 2010
I should add that I picked up the 64-bit executable from Tamas' site
after the 32-bit executable, v.1.6.0, was taking hours to create
overviews.
Thanks.
= David
On Tue, Feb 9, 2010 at 2:32 PM, David Fogel <upperoso at gmail.com> wrote:
> The gdaladdo command is below (for a single overview):
> D:\SRTM\Central_North> "c:\Tamas\bin\gdal\apps\gdaladdo.exe" -r
> nearest -ro --config BIGTIFF_OVERVIEW YES --config COMPRESS_OVERVIEW
> LZW --config PREDICTOR 2 Central_North.tif 2
> On Tue, Feb 9, 2010 at 2:26 PM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
>> And the exact gdaladdo command line you're using ? (must be sure if it's
>> internal or external overviews)
>> Le Tuesday 09 February 2010 23:22:05 David Fogel, vous avez écrit :
>>> Hi Even:
>>> The GeoTIFF file is described below (output from gdalinfo).  The
>>> pre-compiled code is from Tamas' site:
>>> http://vbkto.dyndns.org/sdk/
>>> I am using the MSVC2008 version ( scroll to the bottom of the page ).
>>> This ought to be v1.7.0 with some or all of the code for HFA files
>>> folded into it.
>>> The workstation is running Windows 7 64-bit w/ 8 GB of RAM and too
>>> much disk space to know what to do with .. for the moment.
>>> Thanks.
>>> = David
>>> ----- % cut here % -----
>>> Driver: GTiff/GeoTIFF
>>> Files: Central_North.tif
>>> Size is 119999, 74401
>>> Coordinate System is:
>>> GEOGCS["WGS 84",
>>>     DATUM["WGS_1984",
>>>         SPHEROID["WGS 84",6378137,298.257223563,
>>>             AUTHORITY["EPSG","7030"]],
>>>         AUTHORITY["EPSG","6326"]],
>>>     PRIMEM["Greenwich",0],
>>>     UNIT["degree",0.0174532925199433],
>>>     AUTHORITY["EPSG","4326"]]
>>> Origin = (-31.999583000000001,60.000416333276846)
>>> Pixel Size = (0.000833333333333,-0.000833333333333)
>>> Metadata:
>>>   AREA_OR_POINT=Area
>>> Image Structure Metadata:
>>>   COMPRESSION=LZW
>>>   INTERLEAVE=BAND
>>> Corner Coordinates:
>>> Upper Left  ( -31.9995830,  60.0004163) ( 31d59'58.50"W, 60d 0'1.50"N)
>>> Lower Left  ( -31.9995830,  -2.0004170) ( 31d59'58.50"W,  2d 0'1.50"S)
>>> Upper Right (  67.9995837,  60.0004163) ( 67d59'58.50"E, 60d 0'1.50"N)
>>> Lower Right (  67.9995837,  -2.0004170) ( 67d59'58.50"E,  2d 0'1.50"S)
>>> Center      (  18.0000003,  28.9999997) ( 18d 0'0.00"E, 29d 0'0.00"N)
>>> Band 1 Block=119999x1 Type=Int16, ColorInterp=Gray
>>>   NoData Value=-32768
>>>   Metadata:
>>>     LAYER_TYPE=athematic
>>> On Tue, Feb 9, 2010 at 2:09 PM, Even Rouault
>>> > Could you append the output of gdalinfo on the TIF you make overviews on
>>> > and the exact gdaladdo you're using (mainly if you use one particular
>>> > resampling algorithm) ?
>>> > Le Tuesday 09 February 2010 22:57:26 David Fogel, vous avez écrit :
>>> >> Hi:
>>> >> In the process of moving data into GeoTIFF, I am re-creating pyramids
>>> >> (OVR files).  The good news: It takes fewer than ten minutes to create
>>> >> an LZW Horizontal Differenced compressed 3.5 GB file on a Windows 7
>>> >> box using GDAL 1.70+ ( via Tamas Szekeres site; 64-bit precompiled ).
>>> >> The OVR files are problematic.  Using gdal_translate, I can resize by
>>> >> 50% in less than ten minutes.  Using gdaladdo, the first layer ( "2" )
>>> >> takes hours to complete.
>>> >> This is for SRTM 16-bit data.  It appears that something is amiss.
>>> >> Tips and tricks?
>>> >> Thanks!
>>> >> = David
>>> >> _______________________________________________
>>> >> gdal-dev mailing list
>>> >> gdal-dev at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
