[gdal-dev] Problems with C# ogr_wrap.dll
Tom van der Putte tom at vdputte.nl
Wed Feb 10 10:44:23 EST 2010
 I'm currently having a problem getting the C# OGR binaries to work
on a 64bit WinXP Pro machine, using VS2008 Pro. Ive tried both the
32bit Binaries and the 64 bit binaries.
 * Using the 32bit binaries from
http://vbkto.dyndns.org:1280/sdk/Default.aspx [1] as well as the
general FW windows binaries:
 I set the target platform to x86, added the reference path to the
32bit binaries and added those as a reference. However the
ogr_warp.dll is nowhere to be seen in the references. Calling the
Ogr.RegisterAll(); results in the error :"Unable to load DLL
'ogr_wrap': The specified module could not be found. (Exception from
HRESULT: 0x8007007E)"
 When I manually try to add the dll under the references, it says it
cannot do so, and I have to check that it is either in use, or a valid
assembly.
 * Using the 64bit binaries from
http://vbkto.dyndns.org:1280/sdk/Default.aspx, [2] and the target
platform set to x64, the ogr_wrap.dll file is not in the bin/debug
dir, and I get an error: "An attempt was made to load a program with
an incorrect format. (Exception from HRESULT: 0x8007000B)"
 If I add the ogr_warp.dll to the debug/bin folder, the "Unable to
load DLL 'ogr_wrap': The specified module could not be found.
(Exception from HRESULT: 0x8007007E)" error pops up.
 Any ideas?
 Cheers,
 Tom
Links:
[1] http://vbkto.dyndns.org:1280/sdk/Default.aspx
[2] http://vbkto.dyndns.org:1280/sdk/Default.aspx,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100210/e34598d7/attachment.html
