[gdal-dev] How to supress std io of gdal?
Joaquim Luis jluis at ualg.pt
Fri Feb 12 09:04:50 EST 2010
I have also reported troubles of this type that unfortunately slipped
across the last two gdal releases without being addressed.
http://trac.osgeo.org/gdal/ticket/3195
Here the problem is even worst as the errors are print to stdout
Joaquim Luis
> Sam,
>>   Is there a way to redirect it to some other buffer? Like an internal stream which can then be properly propagated via exceptions or written into a log?
> It is probably not as sophisticated as you want or need but have you tried that:
> gdalinfo out.tif>  stdout.txt 2>  stderr.txt
> Regards,
> Ivan
>>   Thanks
>>   Sam
>>   NEU: Mit GMX DSL über 1000,- ¿ sparen!
>>   http://portal.gmx.net/de/go/dsl02
>>   _______________________________________________
>>   gdal-dev mailing list
>>   gdal-dev at lists.osgeo.org
>>   http://lists.osgeo.org/mailman/listinfo/gdal-dev
