[gdal-dev] Re: corrupt block on AIG dataset
ozak ozak at BROWN.EDU
Sun Feb 14 14:32:15 EST 2010
Hi Even,
Thanks for your help.
I did try it with that test file and it work perfectly. But I'm having
issues with my files. I'll upload a link with one of my datasets (I have
like 500, all over 2GB, and all getting the same issue) in a while.
I have tried to process it on a MAC (using python 2.5 and GDAL 1.7), Linux
server and a windows machine (both using FWTools 2.0.6)...it might work for
a while (I was able to process 5 or 6 files) but then starts creating this
import errors, even on files it has processed without problems before. It's
a puzzle to me, but then I'm quite new to GDAL.
Best,
Omer
View this message in context: http://n2.nabble.com/Re-corrupt-block-on-AIG-dataset-tp4568372p4571318.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
