[gdal-dev] Oracle OCI connection in Python OGR
Abhay abhay.menon at gmail.com
Sun Feb 14 14:45:32 EST 2010
On Fri, Feb 12, 2010 at 11:32 PM, Eric Wolf <ebwolf at gmail.com> wrote:
> Thanks for the replies. Sorry I didn't give more details on the
> environment.
> I am running on Windows, at the command line, both ogr2ogr and the python
> script.
> Created an environment variable for ORACLE_SID=ORCL
> I double-checked my OCI string by using sqlplus to connect:
>     sqlplus scott/tiger at orcl
> This works fine. I changed the script to use that in the call to
> ogr.Open(). No luck.
> I imported gdal and sprinkled print 'Error:', gdal.GetLastErrorMsg() in my
> exception handlers. I got:
>     Unable to open Oracle connection None
>     Error:
> Still no dice. If I take the same script and modify the GetDriverByName and
> Open to use a shapefile, it works perfectly.
> -Eric
> Eric B. Wolf                    New! 720-334-7734
> USGS Geographer
> Center of Excellence in GIScience
> PhD Student
> CU-Boulder - Geography
> GPG Public Key: http://www.h4h.net/ebwolf.public.key.txt
> On Fri, Feb 12, 2010 at 6:56 AM, Abhay <abhay.menon at gmail.com> wrote:
>> On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <ebwolf at gmail.com> wrote:
>>> I'm using GDAL/OGR 1.6.1 with ActivePython 2.6.4-10 and
>>> cx_Oracle-5.0.3-11g. I am trying to connect to an Oracle 11g instance.
>>> This works:
>>>     ogr2ogr -f "KML" emp.kml OCI:scott/tiger "EMP"
>>> What am I doing wrong. This fails, ds is None:
>>> from osgeo import ogr
>>> try:
>>>     d = ogr.GetDriverByName('OCI')
>>> except:
>>>     print "Unable to GetDriverByName"
>>>     quit()
>>> ds = None
>>> try:
>>>     ds = ogr.Open('OCI:scott/tiger')
>>> except:
>>>     print "Unable to open OCI connection"
>>>     quit()
>>> if ds is None:
>>>     print "Unable to open Oracle connection", ds
>>>     quit()
>>> lyr = ds.GetLayerByName('EMP')
>>> number = lyr.GetFeatureCount()
>>> print "Features: " + str(number)
>>> USGS Geographer
>>> PhD Student
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Hi Eric,
>> Form your mail it not clear what is cause of the problem.
>> There 2 scenario here
>> 1) you are on a remote machine form where your trying to connect oracle
>> server machine:
>> a) Have you installed any Oracle Client in your system. Considering that
>> you are using the complete oracle client installation you can use the
>> following  :
>> OCI:scott/tiger@<Tnsname entry for eg. ORCL>
>> b) if you are trying out with Instant client for 11g you should try either
>> of the following
>> OCI:scott/tiger@//localhost/<your ORACLE SERVICE IDENTIFIER for eg ORCL>.
>> 2) you are on the oracle server machine where
>> you must set the oracle SID. like the following
>> on windows
>> SET ORACLE_SID=ORCL
>> or
>> on *nix
>> export ORACLE_SID=ORCL
>> then try your implementation or use methods stated in 1)
>> Rgds.
>> Abhay.
Hi Eric,
What I still did not get is whether your running Oracle Server 11g on the
same machine on which your developing.
Also have you tried connecting the same using "cx_Oracle.Connection" whether
this connect string is working.
Are you using gdal-1.6.1-py2.6-win32.egg install with Python or build your
on using SWIG python implementation.
Interestingly, what I found is that in gdal-1.6.1-py2.5-win32.egg which
install using easy_install seem not work with OCI driver as way it should.
But connection string using cx_Oracle is working. So it seem
gdal-1.6.1-py*-win32.egg is broken for OCI plugin or probably it must be
some setup I must have overlooked will setup, if someone else is working
with same setup could help on this or Howard could comment on this.
I have build my own egg using latest repo of gdal build and is working. If
you need I can share the same egg file (for python 2.6) or wait for Howard
to compile for the latest build of GDAL-1.7 for python officially as you
would need gdalwin32-17 for this along with OCI build plugin.
Rgds.
Abhay.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100215/7c4f5884/attachment.html
