[gdal-dev] Oracle OCI connection in Python OGR
Peter J Halls P.Halls at york.ac.uk
Mon Feb 15 02:22:30 EST 2010
Eric,
    when you installed the Oracle Client, which options did you install?
SQLPlus will install (and work) regardless of whether the OCI libraries are
installed - this has given grief to many here who have not read the
documentation prior to performing the install!  The Oracle tool I have found to
be a more representative test is SQL Developer - it is much nicer to use than
SQLPlus as well and is another install option.
    Of course, it may be that your problem is related to the possible build
problem described by others ....
Best wishes,
Peter
Eric Wolf wrote:
> Thanks for the replies. Sorry I didn't give more details on the environment.
> I am running on Windows, at the command line, both ogr2ogr and the python
> script.
> Created an environment variable for ORACLE_SID=ORCL
> I double-checked my OCI string by using sqlplus to connect:
>     sqlplus scott/tiger at orcl
> This works fine. I changed the script to use that in the call to ogr.Open().
> No luck.
> I imported gdal and sprinkled print 'Error:', gdal.GetLastErrorMsg() in my
> exception handlers. I got:
>     Unable to open Oracle connection None
>     Error:
> Still no dice. If I take the same script and modify the GetDriverByName and
> Open to use a shapefile, it works perfectly.
> -Eric
> Eric B. Wolf                    New! 720-334-7734
> USGS Geographer
> Center of Excellence in GIScience
> PhD Student
> CU-Boulder - Geography
> GPG Public Key: http://www.h4h.net/ebwolf.public.key.txt
> On Fri, Feb 12, 2010 at 6:56 AM, Abhay <abhay.menon at gmail.com> wrote:
>> On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <ebwolf at gmail.com> wrote:
>>> I'm using GDAL/OGR 1.6.1 with ActivePython 2.6.4-10 and
>>> cx_Oracle-5.0.3-11g. I am trying to connect to an Oracle 11g instance.
>>> This works:
>>>     ogr2ogr -f "KML" emp.kml OCI:scott/tiger "EMP"
>>> What am I doing wrong. This fails, ds is None:
>>> from osgeo import ogr
>>> try:
>>>     d = ogr.GetDriverByName('OCI')
>>> except:
>>>     print "Unable to GetDriverByName"
>>>     quit()
>>> ds = None
>>> try:
>>>     ds = ogr.Open('OCI:scott/tiger')
>>> except:
>>>     print "Unable to open OCI connection"
>>>     quit()
>>> if ds is None:
>>>     print "Unable to open Oracle connection", ds
>>>     quit()
>>> lyr = ds.GetLayerByName('EMP')
>>> number = lyr.GetFeatureCount()
>>> print "Features: " + str(number)
>>> USGS Geographer
>>> PhD Student
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Hi Eric,
>> Form your mail it not clear what is cause of the problem.
>> There 2 scenario here
>> 1) you are on a remote machine form where your trying to connect oracle
>> server machine:
>> a) Have you installed any Oracle Client in your system. Considering that
>> you are using the complete oracle client installation you can use the
>> following  :
>> OCI:scott/tiger@<Tnsname entry for eg. ORCL>
>> b) if you are trying out with Instant client for 11g you should try either
>> of the following
>> OCI:scott/tiger@//localhost/<your ORACLE SERVICE IDENTIFIER for eg ORCL>.
>> 2) you are on the oracle server machine where
>> you must set the oracle SID. like the following
>> on windows
>> SET ORACLE_SID=ORCL
>> or
>> on *nix
>> export ORACLE_SID=ORCL
>> then try your implementation or use methods stated in 1)
>> Rgds.
>> Abhay.
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
