[gdal-dev] Re: installing GDAL for pythonwin: can import and use gdal, but not gdal_translate
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Feb 18 01:21:44 EST 2010
ytrapaet,
pythonwin is for python's commands. gdal_translate.exe is a seperate
executable file. You need to run it from the system's command line (Start ->
Run -> cmd). If your environment variables are set as described in the
document you should be able to run it from your command prompt.
On Thu, Feb 18, 2010 at 11:36 AM, anotherObject <ytrapaet at hotmail.com>wrote:
> hi Chaitanya,
> Thanks for the response. Perhaps i am just not understanding or remembering
> terms, but is the pythonwin interactive window not the command line? that
> is
> where i am trying to access gdal_translate (i guess run the exe would be
> more corrent), yet  it completely does not recognize the word
> "gdal_translate" (or any of the other utility names).
> http://n2.nabble.com/installing-GDAL-for-pythonwin-can-import-and-use-gdal-but-not-gdal-translate-tp4590165p4590291.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100218/8026a7b6/attachment.html
