[gdal-dev] HDF5 information regarding Coordinate System and GCP
Pedro Roma pedroroma1982 at gmail.com
Thu Feb 18 06:31:07 EST 2010
Greetings All
Clearly I'm a newbie in this mattters.
Ok, each of my previously mentioned HDF5 files doesn't include GCP points...
Instead of that, pixel geographic position is given in two other HDF5 file
(one for latitude another for longitude). My question is, how can I
geoprocess and rectify this images into a Geotiff file or to be ingested,
geographically projected into GRASS? Any one has tried or had sucess with a
similar problem (but different datasets)?
Best regards,
Pedro
On Wed, Feb 17, 2010 at 7:29 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Petro,
> yes it is not surprising there's nothing specific in the doc of the HDF5
> driver about what to do with GCPs as quite a few other drivers can also
> return GCPs. You're probably interested by a generic tool such as gdalwarp
> to
> rectify the image from the GCPs : see http://gdal.org/gdalwarp.html
> Best regards,
> Even
> Le Wednesday 17 February 2010 13:00:15 Pedro Roma, vous avez écrit :
> > Hi
> > I have specified individual subdataset and I have run gdalinfo but it
> only
> > writes in the terminal window it doesn't store in a specific file to be
> > read.
> > As it says in that link: This driver is intended only for importing
> remote
> > sensing and geospatial datasets in form of raster image. There is nothing
> > mentioning georrectify using GCP points included in HDF5 file.
> > On Wed, Feb 17, 2010 at 11:23 AM, Chaitanya kumar CH
> > <chaitanya.ch at gmail.com
> > > wrote:
> > > Pedro,
> > > You need to specify the individual subdataset of the hdf5 file to
> > > retrieve the metadata. This page, http://www.gdal.org/frmt_hdf5.html ,
> > > shows a way to do it in gdalinfo. GRASS should be in similar lines.
> > > On Wed, Feb 17, 2010 at 4:25 PM, Pedro Roma
> <pedroroma1982 at gmail.com>wrote:
> > >> Greetings
> > >> I'm a GRASS user and I'm dealing with some difficulties with HDF5
> > >> import/translate. I'm using gdal_translate to import HDF5 files to
> GRASS
> > >> but I need to use GCP's information and coordinate system. My question
> > >> is, using GDAL tools how can I import/use GCP and coordinate systems
> > >> that are associated with each Subset and that I can "see" using
> > >> gldalinfo.
> > >> Thank you
> > >> Best regards
> > >> pedro
> > >> _______________________________________________
> > >> gdal-dev mailing list
> > >> gdal-dev at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > Best regards,
> > > Chaitanya kumar CH.
> > > /tʃaɪθənjə/ /kʊmɑr/
> > > +91-9848167848
> > > 17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100218/b93dfa23/attachment.html
