[gdal-dev] Nullable fields in OGR
Thu Feb 18 13:07:00 EST 2010
Jason Roberts wrote:
> Many relational databases allow fields to be set to NULL. Is this
> supported in OGR? How does one detect whether a field is nullable or not?
> Looking at the class documentation, I see functions
> OGRFeature::IsFieldSet and OGRFeature::UnsetField. Are these intended
> for checking whether a field is NULL and setting it to NULL? Or are they
> used for something else, such as determining which fields have been
> modified by a caller prior to him calling OGRLayer::SetFeature?
> When I looked at OGRFieldDefn, I could not find a method that might be
> intended for checking whether a field was nullable (e.g.
> OGRFieldDefn::IsUnsettable).
Jason,
IsFieldSet() tests if a feature field is NULL, and UnsetField() can force
it to NULL if it is not.
There is currently no way to test if a datastore supports the concept
of NULL fields, but if it does not it should just write a default value
(0.0, empty string, etc).
Best regards,
