[gdal-dev] Projection issue with a netcdf file
Kyle Shannon ksshannon at gmail.com
Thu Feb 18 15:13:55 EST 2010
Frank,
I would hold off on that patch for a little bit, I just found an issue.
I also just replied to the other patch I submitted in trac.
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406) 829-6954
kshannon at fs.fed.us
On Thu, Feb 18, 2010 at 1:02 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Kyle Shannon wrote:
>> Frank,
>> I have been working on this issue for some time and the driver has a
>> quirky way of handling spatial reference parameters.  If a tag is not
>> present, the netCDFDataset::FetchCopyParms() function returns a default
>> value.  Currently, those default values are all specified as 0.0.  Because
>> of this, there is no error and my projection is set with several 0.0 values.
>>  I have fixed the standard parallel issue on my local machine and it now
>> supports CF-1 tags(standard_parallel) as well as gdal tags
>> (standard_parallel_1 and standard_parallel_2).  I would like to continue to
>> update the driver for other tags that have been added to CF, but still
>> support gdal tags as well, but I am not sure if my programming methods will
>> be suitable.  I would hate to do a bunch of work and not be able to
>> incorporate it.  Any thoughts on how to go about this?
> Kyle,
> I would welcome you contributing improvements in this area.  I will attempt
> to apply the patches even though I am not so familiar with the details of
> the driver.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100218/e21b73c7/attachment.html
