[gdal-dev] Warp a file from two separate Lat and Long
Andrew Clegg ancl at pml.ac.uk
Fri Feb 19 05:11:21 EST 2010
Hi Luisa,
I think you would need to create the VRTs manually - although it would
be a fairly easy task to automate.
Regards,
Andrew
Luisa Peña wrote:
> Hi Andrew
> But How can I create those VRT, I never used those, from my original
> binaries datasets  (HDF)? It seems that VRT is the key for my problem.
> But I never used it before
> Thanks for your help
> Luisa
> 2010/2/18 Andrew Clegg <ancl at pml.ac.uk <mailto:ancl at pml.ac.uk>>
>     Hi Luisa,
>     I've tried something similar in the past with satellite data. I
>     had 3 files, containing latitude, longitude and value stored as
>     floats. I had some very minor success with the following solution
>     (I got out an image but it seemed to drop to a very low
>     resolution). I'm posting it more in the hope that someone else may
>     be able to spot what I did wrong, because I would still really
>     like to be able to do this.
>     My approach was to create a virtual dataset for each file:
>     sst.vrt (the values):
>     <VRTDataset rasterXSize="1296" rasterYSize="2030">
>      <Metadata domain="GEOLOCATION">
>         <MDI key="X_DATASET">lon.vrt</MDI>
>         <MDI key="X_BAND">1</MDI>
>         <MDI key="Y_DATASET">lat.vrt</MDI>
>         <MDI key="Y_BAND">1</MDI>
>         <MDI key="PIXEL_OFFSET">0</MDI>
>         <MDI key="LINE_OFFSET">0</MDI>
>         <MDI key="PIXEL_STEP">1</MDI>
>         <MDI key="LINE_STEP">1</MDI>
>      </Metadata>
>        <VRTRasterBand dataType="Float32" band="1"
>     subClass="VRTRawRasterBand">
>        <SourceFilename relativetoVRT="1">sst.img</SourceFilename>
>        <ImageOffset>0</ImageOffset>
>        <PixelOffset>4</PixelOffset>
>        <LineOffset>5184</LineOffset>
>        <ByteOrder>LSB</ByteOrder>
>      </VRTRasterBand>
>     </VRTDataset>
>     lon.vrt (longitude): (latitude is basically the same)
>         <SourceFilename relativetoVRT="1">lon.img</SourceFilename>
>      </VRTRasterBand>
>     </VRTDataset>
>     I then tried to run gdalwarp on sst.vrt, trying either '-geoloc'
>     or '-to METHOD=GEOLOC_ARRAY'.
>     Regards,
>     Andrew Clegg
>     Plymouth Marine Laboratory
>     Luisa Peña wrote:
>         Greetings
>         I've used GDAL a few times but this is the first time that I'm
>         lost on what I can do with GDAL to solve my problem. I have 3
>         separate files, one with my data, other with Lattitude and
>         another with Longitude. They have the same size and, as an
>         example,  it means that Pixel (1,1) of data is located in
>         latitude retrieved from Pixel (1,1) from latitude and
>         longitude (pixel (1,1) from longitude). All of them are in
>         WGS84 but without GCP's points. I need to create a
>         georreferenced/rectified Geotiff with this data and, to do
>         that, I need lat and Long. How can I do this?
>         Thanks
>         Best regards,
>         Luisa Peña
>         S.Paulo, Brazil
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>     Registered Office:
>     Prospect Place The Hoe
>     Plymouth  PL1 3DH
>     Website: www.pml.ac.uk <http://www.pml.ac.uk>
>     Registered Charity No. 1091222
>     PML is a company limited by guarantee
>     registered in England & Wales
>     company number 4178503
>     PML is a member of the Plymouth Marine Sciences Partnership
>     Website: www.pmsp.org.uk <http://www.pmsp.org.uk>
>     This e-mail, its content and any file attachments are confidential.
>     If you have received this e-mail in error please do not copy,
>     disclose it to any third party or use the contents or attachments
>     in any way. Please notify the sender by replying to this e-mail or
>     e-mail forinfo at pml.ac.uk <mailto:forinfo at pml.ac.uk> and then
>     delete the email without making any copies or using it in any
>     other way.
>     The content of this message may contain personal views which are
>     not the views of Plymouth Marine Laboratory unless specifically
>     stated.
>     You are reminded that e-mail communications are not secure and may
>     contain viruses. Plymouth Marine Laboratory accepts no liability
>     for any loss or damage which may be caused by viruses.
Registered Office:
Prospect Place
The Hoe
Plymouth  PL1 3DH
If you have received this e-mail in error please do not copy, disclose it to any third party or use the contents or attachments in any way. Please notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.uk and then delete the email without making any copies or using it in any other way.
The content of this message may contain personal views which are not the views of Plymouth Marine Laboratory unless specifically stated.
You are reminded that e-mail communications are not secure and may contain viruses. Plymouth Marine Laboratory accepts no liability for any loss or damage which may be caused by viruses.
