[gdal-dev] Re: Add GCP's to a file
Manuel Massing m.massing at warped-space.de
Fri Feb 19 05:46:08 EST 2010
> Gdal_translation has on option
>  [-gcp pixel line easting northing [elevation]]*
this should also work using the VRT output format, which has the advantage
that the raster data doesn't need to be written to an intermediate file (VRT
"wraps" the original data).
E.g.:
gdal_translate [-gcp pixel line easting northing [elevation]]* -of VRT <input>
<output>
You can then gdalwarp the resulting vrt file.
Incidentally, I wonder if there is a strong reason for not implementing a gcp
option in gdalwarp itself?
Regards,
	Manuel
