[gdal-dev] Gdal 1.7.1 and Python3.1
Thomas Maschler thomas.maschler at gmx.net
Sun Feb 21 17:00:24 EST 2010
I am trying to get Gdal 1.7.1 running with Python3.1 since I was reading that this is possible now, but somehow it does not work.
I am using Ubuntu 9.10 having, python2.6 and python3.1 installed.
I compiled gdal from source. The packages were placed in the 2.6 folder and gdal runs fine in the version
>>> from osgeo import gdal
>>> gdal.__version__
'1.7.1'
Since I want it to use in 3.1, I copied the packages into my 3.1 folder (was this right??) and got the error:
  File "<pyshell#8>", line 1, in <module>
  File "/usr/local/lib/python3.1/dist-packages/osgeo/__init__.py", line 21, in <module>
    _gdal = swig_import_helper()
  File "/usr/local/lib/python3.1/dist-packages/osgeo/__init__.py", line 17, in swig_import_helper
    _mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: /usr/local/lib/python3.1/dist-packages/osgeo/_gdal.so: undefined symbol: PyInstance_Type
Can anybody help?
Thanks in advance
Thomas
NEU: Mit GMX DSL über 1000,- ¿ sparen!
http://portal.gmx.net/de/go/dsl02
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
