[gdal-dev] Gdal 1.7.1 and Python3.1
Thomas Maschler thomas.maschler at gmx.net
Sun Feb 21 17:48:47 EST 2010
Sounds logical, I already had a weired feeling copying the files just like this.
OK, I tried your advice, but I got a long list of errors. Doing the same with 2.6 works fine.
$ sudo /usr/bin/python3.1 setup.py install
running install
running build
running build_py
running build_ext
building 'osgeo._gdal' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O2 -Wall -Wstrict-prototypes -fPIC -I../../port -I../../gcore -I../../alg -I../../ogr/ -I/usr/include/python3.1 -I. -I/home/thomas/gdal-1.7.1/include -c extensions/gdal_wrap.cpp -o build/temp.linux-i686-3.1/extensions/gdal_wrap.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for Ada/C/ObjC but not for C++
extensions/gdal_wrap.cpp: In function ‘void SWIG_Python_AddErrorMsg(const char*)’:
extensions/gdal_wrap.cpp:883: error: ‘PyString_AsString’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘PySwigClientData* PySwigClientData_New(PyObject*)’:
extensions/gdal_wrap.cpp:1274: error: ‘PyClass_Check’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘PyObject* PySwigObject_format(const char*, PySwigObject*)’:
extensions/gdal_wrap.cpp:1347: error: ‘PyString_FromString’ was not declared in this scope
extensions/gdal_wrap.cpp:1349: error: ‘PyString_Format’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘PyObject* PySwigObject_repr(PySwigObject*)’:
extensions/gdal_wrap.cpp:1379: error: ‘PyString_AsString’ was not declared in this scope
extensions/gdal_wrap.cpp:1379: error: ‘PyString_FromFormat’ was not declared in this scope
extensions/gdal_wrap.cpp:1387: error: ‘PyString_ConcatAndDel’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘int PySwigObject_print(PySwigObject*, FILE*, int)’:
extensions/gdal_wrap.cpp:1401: error: ‘PyString_AsString’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘PyObject* PySwigObject_str(PySwigObject*)’:
extensions/gdal_wrap.cpp:1414: error: ‘PyString_FromString’ was not declared in this scope
extensions/gdal_wrap.cpp: In function ‘PyTypeObject* _PySwigObject_type()’:
extensions/gdal_wrap.cpp:1623: error: ‘coercion’ was not declared in this scope
extensions/gdal_wrap.cpp:1623: error: expected ‘}’ before numeric constant
extensions/gdal_wrap.cpp:1623: error: too many initializers for ‘PyNumberMethods’
extensions/gdal_wrap.cpp:1623: error: invalid conversion from ‘PyObject* (*)(PyObject*, PyObject*)’ to ‘PyObject* (*)(PyObject*, PyObject*, PyObject*)’
extensions/gdal_wrap.cpp:1623: error: invalid conversion from ‘PyObject* (*)(PyObject*, PyObject*, PyObject*)’ to ‘PyObject* (*)(PyObject*)’
extensions/gdal_wrap.cpp:1623: error: invalid conversion from ‘PyObject* (*)(PyObject*)’ to ‘int (*)(PyObject*)’
extensions/gdal_wrap.cpp:1623: error: invalid conversion from ‘int (*)(PyObject*)’ to ‘PyObject* (*)(PyObject*)’
extensions/gdal_wrap.cpp:1623: error: expected ‘,’ or ‘;’ before numeric constant
extensions/gdal_wrap.cpp:1603: warning: unused variable ‘swigobject_doc’
extensions/gdal_wrap.cpp:1605: warning: unused variable ‘PySwigObject_as_number’
extensions/gdal_wrap.cpp:1636: warning: no return statement in function returning non-void
extensions/gdal_wrap.cpp: At global scope:
extensions/gdal_wrap.cpp:1640: error: expected unqualified-id before ‘if’
In file included from /usr/include/c++/4.4/stdexcept:38,
                 from extensions/gdal_wrap.cpp:2557:
/usr/include/c++/4.4/exception:35: error: expected ‘}’ before end of line
/usr/include/c++/4.4/exception:35: error: expected declaration before end of line
error: command 'gcc' failed with exit status 1
$ sudo /usr/bin/python setup.py install
running install
running build
running build_py
running build_ext
running install_lib
running install_egg_info
Writing /usr/local/lib/python2.6/dist-packages/GDAL-1.7.1.egg-info
Sicherer, schneller und einfacher. Die aktuellen Internet-Browser -
jetzt kostenlos herunterladen! http://portal.gmx.net/de/go/atbrowser
