[gdal-dev] Loading various DTED files in a single block
Ricardo Cezar Bonfim Rodrigues rikardocezar at msn.com
Mon Feb 22 07:44:59 EST 2010
Hi everyone,
I'm writing a code to find highest terrain elevation in dted files.
I'm already reading the elevations from a dted with gdal. But there
are cases where the region I'm searching the highest elevation
contains more then one file (e.g. s20.dt1, s20.dt1 etc...). So I was
wondering how could I load more than one file in a single pafScanline
and if would be a good strategy to work with. I have also read about
GDAL_DTED_SINGLE_BLOCK=TRUE, but where I set it? is it for a single
file?
Does someone know if there is any implementation which returns the
dted files I should open to access the elevations of given a region
(e.g rectangle including bounds in latitude and longitude)?
I'd be glad to receive tips, references which could help me.
Thanks in advance
Ricardo Rodrigues
Brazil
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100222/68ecd945/attachment.html
