[gdal-dev] Re: Add GCP's to a file
Kim Besson kimbesson1981 at gmail.com
Mon Feb 22 13:48:05 EST 2010
Thanks Mr Paulsen and Jukka
Ok I tried  the command and it seemed to work :) Thanks
By the way, if my image has no Coordinates system and my GCPs corresponds to
a certain projection/coordinate system, How I define now the coordinate
system in which that data is?
Thank you
2010/2/22 Gaige B. Paulsen <osgeo at gbp.gaige.net>
> Pixel and line in the description below are actually two different numbers,
> one representing the pixel (x coordinate) and the line (y coordinate) of the
> point in the image.
> Hope this helps,
> -Gaige
> On Feb 22, 2010, at 12:31 PM, Kim Besson wrote:
> >Hi,
> >Gdal_translation has on option
> > [-gcp pixel line easting northing [elevation]]*
> >I know it works with tiffs but I have not tried it with HDF4. Some working
> >examples and considerations about this is hidden inside a document
> >http://www.scangis.org/scangis2007/papers/r3_rahkonen.pdf
> Thanks Jukka. Although why does it only requires pixel line? The dataset
> that I'm using, Easthing and Northing varies along pixel line. Shouldn't it
> be Pixel column and row (or pixel (x,y)?
> Thanks
> Kim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100222/bbe480c0/attachment.html
