[gdal-dev] Issues repacking shapefiles on Linux with 1.7.1?
Andrea Aime aaime at opengeo.org
Tue Feb 23 12:20:28 EST 2010
these days I'm trying to resurrect the GeoTools OGR datastore (a bridge
between the GeoTools data reading API and the OGR one).
Things are working fine, thanks for the nice job on the Java bindings.
The one problem I'm seeing at the moment is an issue trying to repack
shapefiles, when I run the sql command "REPACK <layername>" GDAL prints
the following error message on the console:
ERROR 4: Failed to create temp file
/tmp\test-shp7354670084102227244_packed.dbf.
Hum... see the mixup between unix and windows separators?
Do you need a stand-alone example to reproduce the issue?
Cheers
Andrea
