[gdal-dev] Converting JP2 to GeoTIFF
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Feb 24 09:47:54 EST 2010
Zoltan,
Can you provide a sample dataset that raised this error?
On Wed, Feb 24, 2010 at 8:05 PM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
> Hi,
> I'm trying to convert a jpeg2000 image to a geotiff, but I keep getting a
> segmentation fault. Please can someone point me in the direction of a
> solution.
> Thanks in advance,
> Zoltan.
> zls at gl1:/mnt/gm0_sdd1/gisortho/t4a/breederivier$ gdal_translate trvr.jp2
> trvr.tif
> Segmentation fault
> zls at gl1:/mnt/gm0_sdd1/gisortho/t4a/breederivier$ gdalinfo trvr.jp2
> Segmentation fault
> zls at gl1:/mnt/gm0_sdd1/gisortho/t4a/breederivier$ ls -la trvr.*
> -rwxr-xr-x 1 1001 geograph        151 2010-02-24 16:01 trvr.j2w
> -rwxr-xr-x 1 1001 geograph    4031979 2010-02-24 16:01 trvr.jp2
> -rwxr-xr-x 1 1001 geograph        417 2010-02-24 16:01 trvr.prj
> $ cat trvr.prj
> PROJCS["UTM Zone 34, Southern Hemisphere",GEOGCS["Geographic Coordinate
> System",DATUM["WGS84",SPHEROID["WGS84",6378137,298.257223560493]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",21],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["Meter",1]]
> zls at gl1:/mnt/gm0_sdd1/gisortho/t4a/breederivier$ cat trvr.j2w
> 1.00000000000000000
> 0.00000000000000000
> 0.00000000000000000
> -1.00000000000000000
> 408298.90989752498000000
> 6312778.31578812000000000
> Usage: gdal_translate [--help-general]
>      [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>            CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>      [-of format] [-b band] [-outsize xsize[%] ysize[%]]
>      [-scale [src_min src_max [dst_min dst_max]]]
>      [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
>      [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>      [-gcp pixel line easting northing [elevation]]*
>      [-mo "META-TAG=VALUE"]* [-quiet] [-sds]
>      [-co "NAME=VALUE"]*
>      src_dataset dst_dataset
> GDAL 1.5.4, released 2009/01/07
> The following format drivers are configured and support output:
>  VRT: Virtual Raster
> etc etc
> Zoltan Szecsei
> Director
> Geograph (Pty) Ltd.
> P.O. Box 7, Muizenberg 7950, South Africa.
> 65 Main Road, Muizenberg 7945
> Western Cape, South Africa.
> 34° 6'16.35"S 18°28'5.62"E
> Tel: +27-21-7884897  Mobile: +27-83-6004028
> Fax: +27-86-6115323    www.geograph.co.za
> No virus found in this outgoing message.
> Checked by AVG - www.avg.com
> Version: 9.0.733 / Virus Database: 271.1.1/2706 - Release Date: 02/23/10
> 21:34:00
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100224/dfe4ff36/attachment.html
