[gdal-dev] OGRSFDriverRegistrar question
Thu Feb 25 09:57:36 EST 2010
Alejandro Mostovoi wrote:
 > Hi All,
 >    How can make OGRSFDriverRegistrar::Open fails when trying to open an
 > ESRI Shapefile and the first parameter "/pszName" has extension
 > different to "shp"/?
 > I know when extension is different to "shp", "dbf" and "shx" it fails,
 > but I need that also fails when extension is "dbf" or "shx".
 > Any idea?
Alejandro,
You could modify OGRShapeDataSource::Open() in
gdal/ogr/ogrsf_frmts/shape/ogrshapedatasource.cpp so that is checks this.
change:
     if( VSI_ISREG(stat.st_mode) )
         if( !OpenFile( pszNewName, bUpdate, bTestOpen ) )
to:
         if( !EQUAL(CPLGetExtension(pszNewName),"shp")
Best regards,
