[gdal-dev] gdal_proximmity.py
Thu Feb 25 10:02:04 EST 2010
Vincent Honnet wrote:
> Hi,
> I'm trying to use gdal_proximity.py. through an installation of FWTools
> 2.4.5 or 2.4.6.
> The first thing is that there is, I think, a mistake at line 150: the
> variable dst_ts is wrong, it should dst_ds, then the exception of the
> try can set the right variable to None.
> My command line is:
> gdal_proximity.py T:\vincent\tmp\SwissBoarder.tif
> T:\vincent\tmp\test.tif -srcband 1 -of GTiff -values 255 -nodata 0
> -distunits GEO -maxdist 100
> that way, the result is:
> Traceback (most recent call last):
>  File "c:\FWTools2.4.5\bin\gdal_proximity.py", line 171, in ?
>    gdal.ComputeProximity( srcband, dstband, options,
> AttributeError: 'module' object has no attribute 'ComputeProximity'
> Did someone use this command that way ? Is my command wrong ?
Vincent,
gdal_proximity requires the "next generation" python api. FWTools still
distributes the old python bindings for OpenEV compatability.  You will
need to use a different environment like OSGeo4W's "gdal-dev" package.
I have fixed the dst_ts thing in trunk now.
Best regards,
