[gdal-dev] gdal_translate with -a_srs option using proj4 syntax and +a=ellipsoid
Cassanova, Bill BCassanova at weather.com
Thu Feb 25 14:07:43 EST 2010
Hi all,
I have a tiff image that has been exported from meteorological software
that has know geographic parameters:
ELLIPSOID_EQUATOR_RADIUS 	6378206.5
ELLIPSOID_POLAR_RADIUS 	6356584
ELLIPSOID_FLATTENING 	0.00339
UPPER_LEFT_X 	-3507992.25
UPPER_LEFT_Y 	6780696
LOWER_RIGHT_X 	3601343.75
LOWER_RIGHT_Y 	2337361
PROJECTION_TYPE 	Mercator
CENTER_LONGITUDE_MERCATOR_SPECIFIC 	-96
CENTER_LATITUDE 	37.910004
CENTER_LONGITUDE 	-95.580002
ROTATION 	0
I am trying to convert this to a geotiff with my eventual goal of
converting it to an unprojected tiff.
First step is to add the geographic information to the tiff:
gdal_translate -a_ullr -3507992.25 6780696 3601343.75 2337361-a_srs
"+proj=merc +lon_0=96w +a=6378206.5 +f=0.00339" src_image.tiff
dest_image.tiff
The failure I get is:
Failed to process SRS definition: +proj=merc +lon_0=96w +a=6378206.5
+f=0.00339
My second attempt was the try the same above command except with a proj
string that does not include the +a or +f options
But instead "+proj=merc +lon_0=96w +datum=WGS84".  This did work.
The problem I am now having is that I bring this image into ArcInfo and
for some reason it is shifted north.  I think that being able to
correctly apply the ellipsoid equator radius and ellipsoid flattening
may fix my problem or am I missing something?
The second step is to create an un-projected image from this data:
My presumption is the below command will accomplish
Just that:
gdalwarp -t_srs '+proj=latlong' -r ${sample_method} ${tmp_image_3}
${final_image
Any help is fully appreciated.
Thanks,
Bill
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100225/36b7eb22/attachment.html
